Hey there! :welcome:
It may be something as "simple" as the wrong prop for your application.
The guru's will know better, but to start with..
No idea how mechanically inclined you are or are not..
Sounds like you should first get a baseline health of the engine as it is now...
Any chance you can run a compression test on it?
Might be able to rent a compression tester from local auto parts store if you don't have one.
Also, spark test with an adjustable open air spark gap tester.. Also available at local auto parts store..
Will spark jump a 7/16" gap on each cylinder?
Post those results and these guru's will be better able to help you..
At least they'll be able to say if there are unexpected results, or if you're looking at a prop change or not, etc...
No better group of knowledgeable minds I've found than right here...
Going to follow along and see how you make out!
Hope it helps!
