Could somebody please point me to the article that shows how to disassemble this gear assembly? As can be seen in the photo the gear on the horizontal shaft is not mating properly with the gear on the vertical shaft. The vertical shaft is missing in this photo because I have already removed it. The next step, I think, is to remove the shaft coming from the twist grip and then reinstall it with the gears meshing properly. It is my understanding that the two sets of gears should both mate with their last teeth.
Also, any tips,of things to do or to make sure not to do would be greatly appreciated.
