The symptoms make me feel like fuel is not getting into the cylinder. However...
I have a 1964 Johnson 60 horse. I replaced ignition last year, all new plugs this year, new reeds, new gaskets, carb rebuild, etc. It seems to be running pretty well. Idles great, sounds great on throttle (haven't had it out, just in a bucket). When I pull plugs, three of them have black residue (the kind that would be expected from a cold 2-stroke). The spark plug in the number 2 cylinder doesn't look like it's even burning anything, or even getting anything to burn.
I am getting good spark with a spark plug tester, so the wire seems fine. Furthermore, I can see slight wear on the plug as though it's being put to work. When I pull the plug just after shutting down, exhaust comes out of the spark plug hole indicating that fuel is, indeed, burning inside. However, the spark plug is very clean. The other three plugs are all dark.
Again, the engine seems, for now, to be running well, but this inconsistency has me a bit troubled. Any thoughts on this?
