RaisedByWolves
- Oct 4, 2017
- 90
I have two 25hp rudes, both tillers and I have some questions. One of these is a runner and the other is a parts unit. The runner is a 96 and Im wondering if there is any difference in the lower unit on this than the lower unit on the 88 parts motor.
Also wondering is the powerheads are same or at least similar as I may want to rebuild the one on the parts motor if it is still salvagable. If it will not even fit the mid section on the 96 Ill just part it out.
And lastly for now, on the 96 engine the carb butterfly goes past level at full throttle which does not seem right to me.The motor runs strong, but the throttle was messed with by the previous owner. Can this just be corrected through the throttle linkage?
