Rook66
- Mar 7, 2018
- 54
First time poster. I just discovered this fine site while searching for parts for my old Johnson 3 hp that I inherited from my uncle back in the 80s and thought I'd drop in and say hey and show what I'm working on.
I used the old motor for a couple of years and then I was transferred on my job and didn't get a chance to use it anymore. Since then it's been sitting in storage since 1988. It was running a little rough when I put it up so now I've started working on it before I run it again.
I've rebuilt the carburetor, installed new coils, plug wires, points and condensers. I'm getting ready to install a new impeller along with anything else that looks like it needs replacing.
Here are a few photos of my progress.
I was surprised to find the carburetor didn't have any gunk inside. I had run the carb dry and dumped the remaining gas from the tank when I stored it so that evidently kept it from gumming up. Here are the parts before cleaning. They look better than some I've had after cleaning in the past.
Carb cleaned and just about ready to go back on the motor.
It looked pretty clean under the flywheel.
Here it is after replacing the coils, points and condenser along with new plug wires.
Carburetor is back on and getting ready to install the armature plate and flywheel.
I'll work on the lower unit next.
