1999 Johnson 15HP Upgrade
Calibra
Hi
I have a fully rebuilt Johnson 2 Stoke, 1999 15 HP engine.
It runs real well with very good compression.
Is there anything that can be done to the engine to increase bhp/power?
My mates who have newer 20HP 4 Stoke engines have that little bit more performance out of their boat.
James
boobie
You could try to do some re-proping Otherwise get a newer motor.
thumbnut
First things first. Get a tiny tach or equivalent, Find rpm at wot. Go from there.
What boat ya got?
thatone123
Banned
I have fooled around with these 15's a lot. In the mid 80's they actually made a 7000 rpm model that hardly anyone seems to know exist. I think that made it for class racing in the upper mid-west. I have tried to index the plugs. Take off the airbox on the carb to try to get some cooler air into the carb. A 2 blade prop that OMC used to make helps. Pretty simple stuff for maybe a small hp gain.
thatone123
Banned
WOW, that Is a anal retentive AH's dream...It would keep me out of the running or even wanting to run!!!
