Cadillac-ack-ack
- Dec 1, 2017
- 104
Got all my needed part (we'll see about that) and just today got a little bit of assembly work started. New pistons on perfect original pins with new wristpin bearings. Got to checking the new piston ring's gaps and could not get them into the cylinder. I'm not sure how much would have to filed from the ends to get them in even if butted. The NOS P/N is correct but the ends actually overlap when fitting into bore is attempted. I really think there would not be enough notch left for the pin location if I filed enough for correct gap. Are they oversize rings I wonder?
