Hi guys, I have a question about my key switch on a 100 hp 1968 evinrude motor. I have power at the switch and power at the selenoid but when I go to turn it over the starter won?t activate. All fuses are good and I had the selenoid tested and it checked out ok. It was working but not now,I am stumped. I also have power at my forward and reverse switich. When I tested the switch I got a light at the selenoid when a turned the key as if to start the motor on the small post at the selenoid. The starter won? t activate at the switch with just touching the wires to kick the starter over either.
