I need help finding the signal hookup connection or wire to the T/T gauge. I have (2) black wires coming for the switch at the T/T unit, to the box in front of the flywheel. Do I have a wire in the harness, to the front for the hookup or do I have to run one up to the gauge from the motor and, where, what color is the wire? Also, can I add an aft switch for the T/T by jumping into the wires from the trim motor?
Thanks in advance- Jerry Ware
