xagneovox
- Feb 3, 2017
- 36
Hello,
Yesterday I was cruising on choppy water and halfway my destination I noticed my trim was not working anymore.
When I operate the trim on the shifter or on the motor I only hear a clicking noise of the relays.
I already tried cleaning the contacts of the relays and manually check all the connections but it didnt do anything.
At the moment it's raining and the boat is still in the water so in a few days I will try some things.
First I will check if the relays work properly with a multi meter and replace if necessairy.
If this is not the problem I will try tapping on the motor while operating and clean the brushes if necessairy.
I don't think it's the battery because when the engine is running it doesn't work either, correct me if I'm wrong .
The hydraulics should be good because before it worked like a charm and it's just the motor that's not running.
Regards,
Jasper
Regards,
Jasper
