I have an Evinrude E150FPLSSV. I'm using the computer diagnostic software for Evinrude. I'm getting the following readings. I'm old school, and referring to the book. I don't know why it's running hot & the readings don't appear in the standard manuals. I just want the instructions to fix this engine, since I'm dealing with something new, if you could help, very much appreciated.
Engine History Report
Model/Serial #: E150FPLSSV/4776027
43 | Engine temp above expected range - port or single
Code | # of Times |
56 | 1 | Cylinder 6 fuel injector open circuit detected
49 | 255 | Air temp above expected range
55 | 1 | Cylinder 5 fuel injector open circuit detected
54 | 1 | Cylinder 4 fuel injector open circuit detected
51 | 1 | Cylinder 1 fuel injector open circuit detected
53 | 1 | Cylinder 3 fuel injector open circuit detected
52 | 1 | Cylinder 2 fuel injector open circuit detected
28 | 3 | Shift assist circuit malfunction
35 | 3 | No oil pressure
22 | 5 | Overheat switch closed
26 | 66 | Battery voltage below expected range/excessive battery load
47 | 255 | Air temp sensor fault detected
43 | 7 | Engine temp above expected range - port or single
14 | 1 | Throttle position sensor above expected range
Code | # of Times |
