This motor is new to me and is difficult to get to shift into reverse. It has the older shift rod connection with the two bolts that fit into a connector between the upper and lower shift rods. I can get it to shift to reverse easily by pressing down on the neutral shift lockout lever, so I don't think the problem is in the gearcase. The problem seems to be the little projection on the bottom of the bracket can't quite slide up out of it's groove (when in neutral) to the reverse position without a lot of force applied to the shift lever. Can the upper bolt on the shift rod connector be adjusted lower on the upper rod? I have a service manual but it doesn't address this issue.
