I bought this 1977 70 hp johnsonback in May or June, Dude i bought it from said it needed the starter rebuilt but pull started it to prove it worked (no electrical stuff was hooked up). I brought it home and didnt touch it for a month and a half while i was working on the boat it was supposed to go on. I got an ignition for it and wired up everything, didnt bother to check to see if it ran because i was going to pull start. Went down to the river and the fly wheel was locked up, didnt think anything of it. Went back to the house and broke the bolt on top and its spinning fine. Before i went back, i wanted to check to see if it ran and im not getting any spark to my 3 spark plugs. What is the possibility of something going out while sitting there that is now causing my motor not to spark? any suggestions on what I should look at?
