150xp prop help
I need help with the correct prop or at least a starting point<br />I just bought a 95 hydra sports 19'cc running i think a <br />90? (e150stlesb) erude 150xp twisting a 14x17 3 blade ss prop <br />no idea on the pitch. I have an intermittent <br />tach problem so i haven't really figured out my WOT rpm but the major problem is getting on plane<br />it took appx 30 seconds with the bow sky high in slight to moderate chop. I trimmed all the way in to way beyond where I should of been back with no change<br />the motor is sitting right as far as height (plate exact at the v bottom) so I was thinking prop was an issue. motor trimmed all in is neg of vertical on the transom when the boat is level so I think transome wedges aren't really the answer.<br />eng runs ok after on plane and was bought with a fresh tune from a cert repair shop. VRO is disconnected. I appreciate any help<br />Steve
