jcframe1983
- Aug 16, 2008
- 2
Honda
B75
Serial #: 3018735
Let me just say I have little experience working with small engines (or piston engines for that matter)
I pulled the start cord too far out and it wouldn't retract.
I figured it would be easy... (I was wrong) So I took it apart and the spring cam un-sprung.
there is a little hook (inside) that mounts to the shive (that holds the pull cord) and another hook on the other side (outside of the spring) mounts to the lower housing of the pull start.
there is a stamped steel ring integrated into the lower section of the housing that the spring must seat into to properly work without binding.
I cant seem to get the spring to properly wind into the ring with out popping off either one of its anchor (pun intended) points.
2 guys have been working on it for the better part of 2 hours, and we are stumped (and imbarresed)
any help?
sorry I cant post pictures, no digi cam.
B75
Serial #: 3018735
any help?
