Welcome Guest - Sign Up today
No announcement yet.
Honda 9.9 2003, dies after idling for few minutes
  • Honda 9.9 2003, dies after idling for few minutes
    My Honda 9.9 was checked in the shop in the water tank and was running fine. Got it checked before buying from somebody. the motor had less than 20 hours.
    After I intalled it on my sailboat , it starts fine but dies after few minutes. It starts fine after dying. When I installed it I had to change the gaz connection to the motor because the old one was for a Yamaha. I put brand new gaz. I noticed that when I squeeze the bulb does not get hard like it used to. Should I buy another bulb and a new line ? Anybody has any ideas ?
    Re: Honda 9.9 2003, dies after idling for few minutes
    It sounds boring but clean the carb. Check out float needle and height/operation. I take it there is fuel in the float chamber as it starts in neutral after cut out? These are just places to start. Try it with a different remote tank.........could be air.
