2000 Tohatsu 40D Idle adjustment
imported_Warren
My 2000 40D needs the idle to be a little higher.....It sputters until I give it a little throttle.
What is the proper procedure to raise up the idle? I'm pretty sure its in the linkage but am scared to mess with it because of the 3 carbs.....Thanks in advance for any help.......Warren
TOHATSU GURU
Re: 2000 Tohatsu 40D Idle adjustment
You would use the idle adjustment screw and raise the RPM....
