Welcome Guest - Sign Up today
No announcement yet.
Steering cable won't come out of Tohatsu M50D
  • Steering cable won't come out of Tohatsu M50D
    The steering cable feels like it is grabbing something on the M50D and won't come loose. It didn't do the the last two times we took it off a Sylvan 16' aluminum boat.How can I get it out please? Thanks.
    Re: Steering cable won't come out of Tohatsu M50D
    Heat it up and drive it out.
    Elvin
    My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
    The 3 Rules:
    1) Look in your service manual first...Then ask me if it is correct.
    2) Understand that your desire to repair your engine does not mean that you have the ability to do so.
    3) If you are confused, take your engine into a dealer..Then let them be confused...At least, in theory, they sent someone to outboard 101.
    • #3
      Elvin,We got some apray lube in it and it softened the grease and it came out. Never thought of heating it, but then I didn't think grease would prevent it from coming out.Thank you.
      • #4
        The grease it's hard and acts like an adhesive.
        Elvin
        The 3 Rules:
        • #5
          Use White Lithium instead of the OB grease and youll be less likely to get frozen up! TM
          • #6
            OK I will. I noticed our Johnson was getting hard to steer too.
            • #7
              The stuff also goes by the trade neme Lubriplate.....AK pipeline tested to 100 below! TM
