I just bought my first decent sized(22.5' Alumaweld)) boat. It has 2006 150 HP Honda outboard. It only had 60 hours on it when I bought it and runs great. I have been using the rabbit ears system to back flush the motor but I see Honda recommends using the flush port connector.
I hooked a garden hose to the flush port connector, no water ran through the motor and it blew the flush port connector hose off of the motor twice.
The motor pumps plenty of water when running as well as when hooked up to the rabbit ears and a garden hose. Is the fact the flush port is not working something to be concerned with?
Also, the boat has a full set of Honda controls and gauges. The gas gauge does not work and is stuck on full. Any suggestions as to how to check if this is the gauge or the sending unit in the tank?
Thanks in advance for any support.
