Welcome Guest - Sign Up today
No announcement yet.
Starter solenoid may be bad, not sure which repalcement to get? Late 80s Nissan
  • Starter solenoid may be bad, not sure which repalcement to get? Late 80s Nissan
    I have a late 80s model Nissan NS25c outboard that the electric starter no longer seems to work. The starter itself seems okay, been poking around with a multimeter and am seeing full voltage going to the solenoid but when i turn the key, nothing happens. Voltage stays the same too. Its probably the original solenoid, says "Hitachi A104-123" on it. Probably the culpirit as far as i can tell. Did a little digging to try to find a replacement but can only find part numbers relating to the NS25c2 that came after this specific engine. I'm not sure if its the same starter solenoid though. Not having a whole lot of luck finding part number info relating to the original NS25c I have. I do have the manual, but it doesn't go into part numbers like that. I did find these which look like they might be right, but i just want to be sure. Any advice? Thanks in advance.
    https://www.tohatsu.us/index.php?main_page=product_info&products_id=10305 6
    https://www.ebay.com/itm/New-Genuine-OEM-TOHATSU-STARTER-SOLENOID-336-76040-0-Superseded-by-346-76040-0/163621358897?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m1438.l2649
    Picture of the outboard itself is attached
    346760400m starter solenoid $77.50
    Paul
    Certified Tohatsu TLDI Technician
    Buffalo NY USA
    • #3
      Right on, thank you.
