Welcome Guest - Sign Up today
Announcement
Collapse
No announcement yet.
Shim for water pump
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • BOWTECH.JUSTICE
    started a topic Shim for water pump
    Shim for water pump
    2002 Nissan 50hp. NSD50A
    I'm rebuilding the lower unit and to the point of assembling the water pump. Per the manual and parts diagram, it calls for a shim to be put on first before the pump housing. Somewhere along the line the previous shim has disappeared and when I was going to order a new one, there were 4 different thicknesses of shims offered. How do I decide which shim it is that I need? Or do I even need one? And before the haters respond about all the bad things of not doing it exactly how it says, I understand all of that, but it almost seems to fit together nicely without the shim. Thanks
  • racerone
    replied
    Mechanics blue / AKA Prussian blue-----Is a product that old timers used.----This can be used to observe proper tooth contact.-------Must pull up on the driveshaft when testing.-----Look into using that stuff.
    Leave a comment:
  • BOWTECH.JUSTICE
    replied
    This is why I love this site. I'm no expert on anything but I'm willing to try anything, so it's nice to be able to get good info from the experienced ones
    Leave a comment:
  • BOWTECH.JUSTICE
    replied
    Ok. So now, with me being a diy'er I don't have the proper tools and the gauge to measure pinion height is expensive. Are there options to measure that height? This outboard is on a rental pontoon and at this time I'm just trying to prolong its life as long as possible for the least amount of money.
    Leave a comment:
  • pvanv
    replied
    too much pinion clearance will prematurely wear all 3 gears.
    Leave a comment:
  • BOWTECH.JUSTICE
    replied
    I'm guessing too much clearance would allow the bearings to move?
    Leave a comment:
  • BOWTECH.JUSTICE
    replied
    Will do that. So what happens with too much clearance?
    by the way, thanks
    Leave a comment:
  • pvanv
    replied
    The issue is you may have too much clearance. You need the Factory service manual to check the LU backlash.
    Leave a comment:
  • BOWTECH.JUSTICE
    replied
    #15 on this diagram
    Leave a comment:
  • BOWTECH.JUSTICE
    replied
    The manual does show one which looks like it's for the pump housing to sit on the rim of the bearing for clearance of the pump seals and the bearings. Rough measurements with a tape measure tells me I should have clearance between the seal and bearing without the shim.
    Leave a comment:
  • pvanv
    replied
    That shim is for setting the lash in the LU. If it never had one, it is likely OK without one. If on the other hand, it did have one and you lost it, you may want to review your Factory service manual and get some dial indicators out to set the lash.
    Leave a comment:
Working...
X
