Welcome Guest - Sign Up today
No announcement yet.
Help on side controls and cables-2006 M30A4-346B
  • Help on side controls and cables-2006 M30A4-346B
    Need cables and side controls .This is for a donated motor to a Non Profit Organization restoring a 1957 16 ft lyman under restoration to be raffled. I think this a 2 stroke /carb model w/ elect start? Need help on what to get . Serial #046829XF joehegolf@yahoo.com
    Did the motor ever have remote controls? If not, you will need the SRC kit of parts to connect the controls at the motor end:
    3A1838801M SRC KIT;9.9B-18C,25,30 $188.17
    Cables are standard Morse type. Measure as per usual: distance from control to transom, add distance from rt corner of transom to motor, add 3 feet for a steering "loop" so the motor can turn without the cables binding.
    If it is electric srtart (is there an electric starter motor?) then you will want an RC box with key switch. Does it have power tilt/trim? If so, your RC box will need that switch as well. If it has remote steering, you need the appropriate box to accommodate that as well.
    3B7-84360-0 REMOTE CONTROL BOX (RC5D) 1 FOR MF/EF TYPE / TOHATSU 3B7Q843602 RC BOX, RC5D (MFS4B~30C),W/O ELECT START $341.05 Low Stock
    3B7-84350-1 REMOTE CONTROL BOX (RC5C) 1 FOR EP TYPE / TOHATSU 3U2B843500 RC BOX, RC12C (MFS8/9.8),W/ ELECTRIC START W/O PTT (2018) $421.65 Out of Stock
    373843602M REMOTE CONTROL BOX (RC5D) 1 FOR MF/EF TYPE / NISSAN 373Q843603 RC BOX, RC5D (MFS4B~30B), AMB-W/O ELECT START $385.87 Low Stock
    383843502M REMOTE CONTROL BOX (RC5C) 1 FOR EP TYPE / NISSAN 3U2B843500 RC BOX, RC12C (MFS8/9.8),W/ ELECTRIC START W/O PTT (2018) $421.65 Out of Stock
    Paul
    Certified Tohatsu TLDI Technician
    Buffalo NY USA
