Welcome Guest - Sign Up today
No announcement yet.
Alarm At Idle, Silent As RPM Increase
  • Alarm At Idle, Silent As RPM Increase
    Nissan outboard 1996 90 hs alarm goes off in control box at low rpm. Throttle up and it goes off. In repair shop twice to no results
    You did not mention model. Year is irrelevant. Assuming you have an NS90A. You can DL your owners manual from https://tohatsu.com/tech_info/manuals.html
    Page 62 shows the alarms for the 90A. Do you get any indicator lights?
    You can use an IR thermometer to see if you are running hot. If your water pump is worn, it might not pump well at idle. How strong is the telltale stream?
    Paul
    Certified Tohatsu TLDI Technician
    Buffalo NY USA
    • #3
      Will be good to know if that 23 year oldie motor was used on fresh or salt water along thermo and heat probe condition if doing their work as they should or already being faulty . If you can place your hand firm on the powerhead and hold it there for say 3-5 seconds soon after the warm up time is over will be OK, if need to remove it inmediately the motor is experiencing overheat issues that will need to be addressed properly.
      Happy Boating
      Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
