fishslayer73
- Jun 15, 2019
- 6
Here is the back story. I bought this motor used under the premise that it needed carb cleaning and a new impeller. I changed the impeller and housing, cleaned the carb and it fired right up and purrs like a kitten. Now the problem. I am not getting water out of the pee hole so I removed the intake and found rubber chunks (impeller) by the thermostat and pluging the pee hole port. I tried flushing all water ports and can not get water to run backwards out of the water tube. When I changed the impeller and housing There was what looked like a new impeller but the old housing was full of impeller chunks as if the previous owner had run a bad impeller and then changed to a new one sending chunks into the motor. I am looking for any ideas you all may have as to how to unplug this problem. Thanks to all, Jason.
