Welcome Guest - Sign Up today
No announcement yet.
I am have problems with installation remote control tohatsu 40 tldi
  • I am have problems with installation remote control tohatsu 40 tldi
    I am not sure the remote control of the motor carburetor can be used with the tldi machine or not.
    Because I saw that there are 2 plugs and 3
    thank you.
    What is your actual model of motor, and which control do you want to use? Probably need the RC5F,
    3GFQ845001 RC BOX, RC5F, ALL TLDI/MFS40/50A $683.05
    Paul
    Certified Tohatsu TLDI Technician
    Buffalo NY USA
    • #3
      • #4
        Motor model MD40B2
        EFTOL
        • #5
          • #6
            Looks like the wrong control box. This is the one you need. Note that there are two connectors at the motor end, plus the tilt wires.Click image for larger version  Name:	002-21024-4_RC5F_FIG03.JPG Views:	1 Size:	81.1 KB ID:	10738921
            Paul
            Buffalo NY USA
            • #7
              Please tell me
              Can we modify it?.
              • #8
                Yes, but not cheap.
                3T5761151M CORD ASSY B (L=6200MM) $367.80
                Paul
                Buffalo NY USA
                • #9
                  However, that is less than buying a whole new box:
                  Paul
                  Buffalo NY USA
                  • #10
                    You thank vary much​ paul
                    I have a question.
                    I followed everything for purge the air but can not purge the air.
                    • #11
                      • #12
                        Did you open the bleed screw and let the oil flow out through the oil filter?
                        Paul
                        Buffalo NY USA
                        • #13
                          this yes or not. If yes. Yes i do.
                          • #14
                            When you open the bleed, if the oil tank is full, the oil will push the air out.
                            Paul
                            Buffalo NY USA
                            • #15
                              It should be open the bleed until not the oil out right.
                              Thank you.
