This is part warning to others with older motors, and part curiosity to know if anyone else has had this problem. I had a sliver of rubber clog the float valve on one of my carburetors, preventing that cylinder from getting any gas. As best I can tell, the sliver (pictures below) appears to be a piece of gas line, though it may have also come from the fuel pump. It's about 9mm long, appears to be slightly curved, and is extremely brittle. I'm now replacing everything rubber downstream of the fuel filter, including the pump, to prevent it from happening again.
This could have been a life threatening situation. My teenage son was driving as we were traversing a very busy inlet on a Saturday afternoon, headed into the ocean. Suddenly my 1999 50HP Honda, which for the last 20 years has been rock solid, was down on power and shaking, no longer able to get the boat on plane. It was obvious one cylinder was out. Fortunately the seas were mild, so I was able to trouble shoot enough on the water to determine that the bottom carburetor was bone dry, no gas at all, and we made the return trip slowly on 2 cylinders. The cause turned out to be the ~9mm and very brittle sliver of rubber (pictures below) clogging the float valve on the bottom carburetor from the supply line side. As best I can tell it appears to be a piece of fuel line, and I'll dissect the fuel lines to verify as time allows, but everything rubber plus the pump is being replaced to be safe. Is this another ethanol related casualty?
If you have an older motor and don't want to risk being stranded, it might not be a bad idea to replace all rubber hoses and the fuel pump if you haven't already!
