Hi all,
I am new to the forum and not terribly experienced at working on my outboard so please be patient. Let me start out by saying I am on an extremely low budget so I cannot take my outboard to the dealer. I bought this boat about 6 years ago for 1100 dollars and it has been a great little boat and motor but last fall when I drained the lower end oil it was pure milk, and I did notice oil rings hitting the water coming from the prop area during the summer. I pulled the prop off and found braided fishing line imbedded in my prop seals not to mention they just looked old and all beat up. To make a long story short I bought a lower end seal kit and am trying to do the seals. I have watched youtube videos on the process and have managed to remove the bearing carrier and prop shaft seals from it. however inside the bearing carrier housing/lower unit housing there is a small rod that clearly is supposed to go into the end of the prop shaft along with a steel ball the fell out of the hollow end of the prop shaft when I removed the bearing carrier. This rod is supposed to go into the prop shaft, push against the steel ball and engage shifting of the gears.
So here is the problem the little push rod at the back of the housing is angled up so when I try to put the bearing carrier/prop shaft assembly into the housing it does not line up with the rod because of how the rod is angled up. I reached in with a long thin screw driver to try and angle it down a bit to line up with the prop shaft, it moves a bit but starts pushing on the gear inside and will not go completely straight because of the gear, however the gear will move a little but then gets stopped by the drive shaft gear coming down from the top?
all the videos I have watched people just remove the bearing carrier pull out the old seals put in the new seals and put everything back into place, however that does not seem to be the process with this motor?
I was hoping someone experienced with these motors could point me in the right direction? as this is my only means of getting out on the water and Walleye season is upon us. Thank you in advance for any advice you can offer!
