That damaged prop is removed, I just put it there so it could be seen as to what it took to get it off. The metal part is still there and does that need to be removed or does it stay? I see no shear pin anywhere and that is what I don't get. There is a a spare shear pin and cotton pins on a rubber holder put on factory, so there must be a shear pin in the prop hub, right? The metal hub holds the prop on with very large thick splines or nubs. So maybe that was a newer design that did not need shear pins but the spares were left on the motor? See photo on page 2
