Tarinazo
- Feb 18, 2019
- 55
Hello, I have a new-to-me mid 80's Honda B100L that was used on saltwater, before starting it for the first time in my test tank, I cleaned it up real good: carb, thermostat, impeller, manifold, hoses, fuel pump. It had lots of sand and flaky residue in the internal... the cleanup helped a lot.
Before having it all back together, I had to make a manifold and carb gasket because the one's on it ripped while taking those parts out. For the manifold, there are two gaskets, the one that has contact with the engine block was intact, so I left that on there, but the one I had to make is the one that makes direct contact with the manifold... I had to make them because it's hard to get OEM parts here in Mexico where live. I used a gray asbestos free gasket material bought at an auto repair shop, 1/16 thick.
So once I had the parts back together and it was time to start the engine for the first time... for me, choke on, first pull and the engine started immediatly and idled perfectly, I couldn't believe it.
The bad news started as soon as I took the choke off... it revved at high RPM's and then shut down. It took me 3 or 4 pulls to start it this time with the choke out, once again purred perfectly but as soon as i puched the choke same thing would happen.
I'm suspecting an air leak in those gaskets I made, I'll do the "ether spray" thing to find those air leaks as soon as I get the engine on the working bench again (right now I'm struggling with a 6hp Merc, made a post also).
Also, I had this Honda engine running for about 10 minutes most and the water in the test tank turned out gray with heavy black oil on the tank's walls... what could this be?
