Sea Rider
- Sep 20, 2008
- 12,345
On last 100 hour use the gear oil of my 18 HP was found with some milky portions not fully mixed though, apparently the seals are in the process of being fully shot and in need to order a lower leg kit shortly. As not sure of this situation will give it a go 50 more hours, drain and inspect all the oil to know.
Was wondering what could cause a premature o'ring failure if gear oil is changed each 100 worked hours, prop has never hit a under water object, lower leg works in clean non sandy waters condition.
The OB has already metered 900 hours of constant well cared use. In my previous 18 HP horses with 1 K metered worked hours have not seen this situation before. Seems it's proper time to sell it as summer is close and install a new one LOL!!
Happy Boating
Happy Boating
