bluntforce
- Jun 24, 2012
- 8
where does the idle circuit get its fuel flow from? i can remove the small, flat head screw next to the pilot screw and run a mig welder wire thru three holes. one comes forward to air inlet, the other two are in the air chamber close to butterfly. tiny holes. When using carb spray, i now have great flow thru them all, but where is the fuel feed?
To get my engine running, i pull the choke out, pull on string, it pops off right off once on first crank, i push choke partially in, and it starts. has high idle then comes down quickly to a stall. if a play with the throttle, it will keep running.if l leave it partially choked, it will maintain a high idle then begin to surge and die. i can restart it each time with same procedure.
any input is appreciated.
thanks
thanks
