vdotmatrix
- Nov 9, 2016
- 56
HELP!!! Ahhh, i am glad I got that out!!! I am trying to remove the outboard from a Catalina-25 that has a remote throttle/shifter. I need to do the spring maintenance and the motor must come off. I removed the cowling. I removed the "R" hitch pin from the throttle and shift lever inside the motor. So what's the problem? The outside cable is free and clear, The other cable is not and is trapped between the two levers. I have the shop manual but have not found the idiot's guide for removing the motor for spring maintenance section. At one point it refers to moving the shifter to WOT (wide open throttle)....I am at home and perhaps I didnt have it all the way open to free the cable. I also removed the throttle/shift bracket on the front of the motor but still couldn't free the one cable. I don't want to take apart any linkages that would require any major adjustment to the linkage.
Does anyone have any ideas or if you have that manual 1992-09 repair manual for Nissan/Tohatsu #1500, point me to the page idiots's......
thanks in advance.
thanks in advance.
