Mr. PapaGeorgio
- Sep 3, 2012
- 28
Howdy, Y'all! I have a 1987 Force 50 which has not given me trouble in the two seasons I've been running it. In firing it up this spring, though, I have no water coming out of the upper unit when it runs. I have tried the leaky muffs on the lower unit, tried taping up the gaps where the water was not going into the lower unit, and even tried raising a bucket of water up to the intakes on the lower unit. There was about an eighth of an inch gap above the water that I'm guessing air was entering the lower unit. Is my only hope to launch her and test the motor on the water? Or is there a process to check the water outlet for it being clogged? Worst case scenario is that I launch and the water still doesn't flow out. Then I am back to the clogging question.
Thanks for any help!
