Four wires are found under the dash, Red, Orange, Purple, Black.
Red - 12 Volt Power When Key is on
Orange - ASSUMING Heat Alarm based on reading posting forum
Purple - ASSUMING Tach
Black - ASSUMING Ground
Red and Orange were connect to leads of warning horn
Purple and Black not connected to anything
All 4 of these wires and enclosed in a cable running to dash and I think go straight to motor but I haven't traced (new old boat)
That being said, First Question
On my other boats in the past when I turn the key on to start, I would hear a warning chirp, I guess telling me the work and wiring is good. I have tested the horn by disconnecting and touching to battery and it works. Does the 1992 Force 70 HP motor have this warning chirp or am I trying to fix something that don't exist? When I check voltage between the Red and Orange and turn key on I see a fraction of a second of .03 volts. With key on, Orange and Black have 12 volts.
Second Question,
This boat does not have a tach or has it ever had a tach. If the Purple wire is the tach feed and Black is the Ground, are these the only two wires needed to install a tach? If so I would consider installing one and if so can anyone recommend an affordable tach and what brands/type are compatible with Force?
Thanks in advance for your reply
Second Question,
