So a few months back, I had no spark on #2 cyl & eventually brought it to a mechanic for diagnosis. He told me the trigger was bad because dva was 0.2 on trigger instead of the required 0.3+. I took my boat back from him and replaced the trigger myself. It did fix the problem and has been good since.
Last week I had my boat out and after beginning to head back to the ramps I experienced a loss of power. It sounded familiar to me(like firing on only 1 cyl) but I was able to get back without calling a tow. Tested my boat today and it started fine and idled normally for 3 minutes and then started idling and sounding very rough like it did that day. My tests showed that I had no spark on #2. Now I've tested with my dva meter and resistance on trigger and I have what the tests are saying another 'bad trigger'
I went by the specifications on this document ISSUU - CDI Electronics Troubleshooting Guide - 2012 by CDI Electronics page 19
My trigger shows 0.1dva connected and resistance 28ohms on one wire set while the other set shows 0.35 dva and 45 ohms.
Is it possible that a trigger assembly went bad this fast?? I bought the trigger from outboardignition.com and I don't know what to do now. Do I just go buy another one?
