Guys. Old thread that should have been buried (like the engine) but the tilt now bleeds down quite quickly. Cant find parts listing for this engine with tilt and trim but want to replace the valve body. The cylinder assembly is stamped 455545 which I have found was used on the following engines in the link. It lists the valve body used on those engines as F17564 which is readily available on ebay. The parts diagram that pnwboat so kindly highlighted for me identified the valve body as FK654541. Unless I'm wrong these are the same part? Your guidance greatly appreciated.
