ctaylor517
- Aug 3, 2013
- 2
I am in the process of installing a force tilt and trim unit on my bluefin sportsman 1700. it's a 50 hp 1988 that did not have tilt and trim originally. I have already installed the proper toggle switch in the dash. (don't have one on the remote)
Do i need to take a hot wire from the ignition to the center terminal of new toggle switch?
There are two red wires coming off the relays on the motor side, I am assuming I can hook those up to the circut breaker that is already on my motor??? or do i need a separate circut breaker?. Looking at some of the other forums, I am hesitant to hook it straight up to the battery solenoid. Any help would really be appreciated. Thanks
