Welcome Guest - Sign Up today
No announcement yet.
Clamp torque
  • Clamp torque
    Hello,
    I am attempting to replace the port side motor clamp this weekend coming up. To prevent the alum clamp from splitting like my other one did, what is the correct torque for these bolts?
    Click image for larger version
ID:	7184746Click image for larger version
    Thanks,
    Tom
    1989 Ebbtide Campione 180
    1989 Force 150 horsepower
    In rememberance of...
    "They that go down to the sea in ships"
    Re: Clamp torque
    WHAT? You haven't replaced it yet?
    I have never seen a spec for the transom clamp bolts. However, I can say that the torque value a fine thread 1/2 inch bolt can carry is great enough that the transom would be crushed. Simply tighten them until the fiberglass on the inner transom starts to deform then stop.
    OR, you can use the multiple grunt method with a breaker bar and pull the bolts and washers through the transom. LOL
    • #3
      Re: Clamp torque
      Looks like a lower through bolt so snug with a little plus would be enough.
      When goals have no clear focus, neither will the actions of the people trying to achieve them
