Welcome Guest - Sign Up today
No announcement yet.
Help wiring ignition switch-1995 Force 120 HP
  • Help wiring ignition switch-1995 Force 120 HP
    I purchased a new Sierra MP39090 "universal" 6-post ignition switch with push-choke for my 1995 120HP Force outboard. Dummy here did not make a note of which wires connect to each post since my manual has a wiring diagram and the letters on both switches are the same (Clockwise-I,M,S,C,B,M). However, the wiring colors in the boat do not fit the description of what is in the manual. (Yellow w/thin Red; Yellow w/thin Black; Red w/thin Blue; Solid Black; Black w/thin Yellow; 3-wire combo [2] Purple [1] Blue w/thin Yellow).
    Can anyone help?
    Thanks a boat load!
    Re: Help wiring ignition switch-1995 Force 120 HP
    Click image for larger version
    Not sure,maybe this can help?
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    88 Bayliner 21CC 2001 Mercury 225 HP EFI
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM I WON'T ANSWER AS MY SYSTEM CAN'T REPLY TO YOUR EMAILS
    • #3
      Thanks, Jerry, but the color combinations aren't the same as mine.
      -Yellow w/thin Red stripe
      -Yellow w/thin Black stripe
      -Red w/thin Blue stripe
      -Solid Black
      -Black w/thin Yellow stripe
      -3-wires combine with (2) Purples and (1) Blue w/thin Yellow stripe.
      • #4
        I'm having the same issue. Were you able to fix it?
        • #5
          I had to get an expert. The stator was bad. Apparently, these are known to go bad. Tech used OEM parts. Not cheap, but runs like a champ, now. There is a thread on this issue at http://forums.iboats.com/johnson-evi...oms-80984.html .
          Good Luck!
          • #6
            Do you have the same color coding on your wires? See if this will help:
            M1 -WHT OR BLK/YEL - this is nothing but a ground wire for shutting the engine down. It should have continuity to ground
            M2 - BLU OR BLU/BLK (Usually there are bundle of wires here use to ground or kill the engine by shunting the CDM's to ground via M1
            I - RED/BLU - aux power wire
            C - GRN OR YEL/BLK - choke wire
            S - YEL OR YEL/RED - this runs straight to the starter solenoid via the neutral switch
            B - RED - this one is really easy to ID by doing a voltage test. This a hot wire should read 12V to ground - battery wire
