Hi Guys, I have an old Chrysler Sailor 10 outboard with very little use. It has been stored for years and I think it's about 1974 vintage. It starts and runs well when tested with the leg in a tub of water but I'm not sure if the cooling water is pumping. Should it come out of the two small holes below the engine housing, or does it come out with the exhaust? I don't want to run it for too long until I can be sure it's pumping.
How do I access the water pump/impeller? Advice would be appreciated.
