Re: 1986 bayliner force tilt fluid change
1972-1987 factory original can use any fluid. ISO32 hydraulic oil is best in warm climates. AW32 is best in colder climates.
1988-1992 and all aftermarket valve bodies should use 30W non detergent motor oil. If you use a thinner oil then the engine may buck while lowering. This can be mildly offset by using a non detergent motor oil in the shock absorber.
1992-1994 Eaton pumps should use iso32 or aw32.
Certain blends of ATF can be used on the Eaton pumps but run the risk of causing oring failure on big engines. At very high pressure something in the ATF impregnates the rubber and causes it to become fragile. ISO32 is a better choice than ATF with equal or better anti-foaming, moisture absorbtion, anti-shearing, and seal protection qualities.
