surfsalterpath
- Aug 6, 2003
- 116
how do I 'replace the trim relays?"
My tilt/trim button in the throttle control stopped working, I think.
It was acting weird at beginning of season. Sometimes when engaged
nothing would happen. The the next time it work work-you could hear
it engaging and the engine would go up and down. Sometimes the button
would not disengage after I took my thumb off. Like it was stuck in up or
down. Now I get no response when pushing the tilt/trim button up or down.
This thumb button is in the throttle control on the captain's stand.
I suspect the 'trim relays' have failed. How do I replace these 'tilt/trim relays'? Thanks so much. You guys helped me replace the tilt/trim piston last year. The tilt/trim motor I replaced ~3yrs ago.
I appreciate your advice!
