Welcome Guest - Sign Up today
No announcement yet.
will not pump water impeller ok chrysler 10hp
  • will not pump water impeller ok chrysler 10hp
    i have a 10hp chrysler sailor which will not pump water i have had the leg off and the impeller looks OK i spun the out put shaft with an electric drill and it would only pump when the water level was over the impeller housing and it wasn't a brilliant output but that could just be the drill i would think a couple of thousand revs
    Re: will not pump water impeller ok chrysler 10hp
    Fill out the profile,you might be close to someone who can help.
    New impeller? How old.Housing scarred?Pics?
    The drill aint gonna do it.The pump usually starts while deep enough in the water.Then it will suction while it's moving.
    Replace the impeller it's only a few $$$ J
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    88 Bayliner 21CC 2001 Mercury 225 HP EFI
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM I WON'T ANSWER AS MY SYSTEM CAN'T REPLY TO YOUR EMAILS
