Welcome Guest - Sign Up today
No announcement yet.
Won't go in Reverse - Things to check?
  • Won't go in Reverse - Things to check?
    1987 Bayliner Capri
    1987 Force 125
    http://www.reinsmith.net/boating.aspx
    Re: Won't go in Reverse - Things to check?
    I assume it is the same model as noted in your signature? 1987 125HP? Linkage is where I would look first. I had similar problems after I re-built my 1988 125hp power head. The linkage adjustment located below the bottom carburetor was out. Hard to get to, but solved my problem.
    • #3
      You need to adjust the shift linkage on the right side of the engine. The Clymer and Seloc books both have the procedure.
      John
      sigpic
      Regards,
      John
      • #4
        That's where I will start then.
        Thanks for the input
        M
        1987 Bayliner Capri
        1987 Force 125
