maxum247
- Sep 18, 2007
- 1,363
1989 125 Force Spark Problem!
Cylinders 1 and 3 have a constant but weak spark and the motor is misfiring on those cylinders.
Cylinders 2 and 4 have a constant strong spark at all times.
I changed out the stator with a new one when I first got the boat a few summers ago and that didn't help, still the same problem.
Have checked and cleaned all grounds several times over the seasons.
Checked and rechecked the wiring and all appears to be correct with no broken wires.
Swapped coils around and the problem didn't change.
I feel like I'm overlooking something but am not sure what else to try at this point.
max!
max!
