Hi,<br /><br />I'm not sure if that is what it's called, but it is the little spring sort of clip that slides over/around the motor end of the throttle cable to lock the cable end onto the little ball-joint piece bolted to the rear starboard side of the block. Know the thingy I mean?<br /><br />I found a very hard to see exploded diagram (thanks again eurolarva), and found a part number, FA58976-1 that is the "throttle connector" for ~$27... I have one of those on the way to me via a local dealer.<br /><br />I suspect this piece is the whole end piece that gets threaded onto the throttle cable. Hopefully it also includes the little spring clip that slides over it (can't tell in the picture).<br /><br />Anyone know what I'm talking about, or what it is properly called, or whether they're available separately from the $27 piece? It looks like a <$1 thingy. Dealer guy was nice enough, but didn't know anything. I can probably bodge something up to hold the cable on in the mean time.<br /><br />Thanks...
