Broken Bolt on Exhaust Plate
turtle1173
Hello all,<br /><br /> I have been working on my 1976 55 HP Chrysler. After slowly working out the bolts on my Exhaust plate, one of the heads snapped off. I had been using Marvel Mystery Oil Lubricant. <br /><br /> The bolt was coming out but I guess I put too much pressure on it. I didn't think I was but it obviously was enough to break it.<br /><br /> The end of the bolt is very slightly below flush with the surface. It is a 3/8" bolt.<br /><br /> What do I do from here? I have never done this before so please give me step by step help. I've read some previous posts about something called an "EZ Out" but I don't know what that is. Would this be a good option or perhaps something else?<br /><br /> The bolt is in an accessible place so that is positive at least.<br /><br />Thank you for the help.<br /><br />Shane Williams
12Footer
Re: Broken Bolt on Exhaust Plate
Well ok.<br />Since it is broke-off BELOW flush, your best bet is to get a welder to try to tack-on a shaft you can grab a hold of. Is the plate off?<br />If not, go ahead and remove it,in case any more break. Don't feel bad. It happens 9 outta 10 times, and is why I gave you the procedure. But even after every precaution has been taken, it can still happen The shaft of the bolt was probably much thinner than a new one,due to corrosion.<br />If you have removed the port plate, what did the ports look like? Any sign of discoloration on the block or plate surfaces, or any sign of leaking-by the gaskets?<br />If they are relatively clean, you aren't done yet (with the engine troubles).<br /><br />EZouts werk great, but you must drill a hole in the center of the stud for it to grip. This is next to impossable to do, at the same time, keeping the drill bit centered in the stud, as oposed to drifting-off into the softer block (yuk).
turtle1173
No, the plate is not off yet. I have one bolt on the bottom that I can barely get to budge. I've soaked it down with the lube and am going to let it set over night. I hate for that one to break because it is in a very bad location. The broken one is on the top.<br /><br /> Let me ask you this, will the plate pull off with the broken bolt or is the plate threaded? The other bolts that I have removed are very corroded. I know the exhaust plate has never been removed because the white paint was perfect on all the bolt heads.<br /><br /> Any good advice to getting the bottom bolt removed? Do I need to buy a torch or something? <br /><br /> I don't have access to a welder of any kind. If I drill a hole in the bolt, what do I need? Any special kind of drill bit? Do they make drill bits that go counter-clockwise? How big of a hole do I drill?<br /><br />Thank you,<br /><br />Shane
12Footer
The fact that these bolts are corroded tells me there has been some exposure to water, and probably salt water, where there should be none.<br />I agree.By all means, take your time on the remaining bolt!!try turning it in slightly,and keep it soaked. Tap it gently,to get the blaster into threads as best you can. If it takes you a week to get that last one out, it takes you a week. <br />The plate is held-on by the bolts,and does not thread-on to the block.<br />These have a torque sequence,just as the head bolts do.<br />The drill bit required is an ordinary metal-drilling bit. The trick is keeping it centered in the hard bolt shaft material,and not having it drift-off into the side,where the aluminum block is. I would take this boat and all to the nearest machine shop, and ask them to extract it before I attempted to drill and EZout it.<br />Besides, one you have the plate off, you just might have enough of a stud there to grab with visegrips. If not, it should be an easy task for a welder and about 15minutes of his time.<br />The heat he uses will also help. Be sure to ground-out the CD box before any arc is used tho, lest you smoke it.
12Footer
The ease-outs are counter-clockwise.
Yepblaze
If it had been turning before it broke off, a drill bit may get a bite and run it back into the threads enough to add more oil, finish drilling to accept an easy out, then remove. You do not want to break off the easy out, as that would leave a broken metal piece in there harder than a drill bit.<br /><br />Here are some websites dealing with broken bolt I found by using google.com <br /><br /> http://web.dimebank.com/tech/BrokenBolt.html <br /><br /> http://www.gis.net/~manjo/removing_broken_studs_bolts.htm <br /><br /> http://216.117.154.182/autorestorationtips.htm <br /><br /> http://www.ytmag.com/articles/artint116.htm <br /><br /> http://www.truebite.com/remove/
Hooty
There are some better penetrating oils than M.M.O. Try some stuff called "PB Blaster". I think you can find it your local NAPA or other auto supply store. Let it soak for a day or so if necessary.<br /><br />g'luck & c/6<br /><br />Hooty
12Footer
Yes, Blaster is great stuff!
93bronco
Ensign
i have used ez-outs made by craftsman & other brands they tend to be brittle and break off. leaving you with a mess. they are ok for non- corroded bolts/studs but you still have to be very careful.
norman158
you can buy a left hand drill bit so if the bolt comes loose it will back it out
John from Madison CT
Same thing happened to me a couple of weeks ago, BUT on a much newer motor.<br /><br />In both cases I had about 1/4" to grap with a visegrip but the first one still broke.<br /><br />A friend who works on motors took a center hole punch and managed to get a score in the center of the screw and he drilled it out using progressively larger drill bits. It worked well. We cleaned up the threads on the inside using a "tap" for that exact size threads. <br /><br />The second bolt came out by holding with the visegrips and using tons of heat from a propane torch. Kept it there a good 10 minutes and even as we slowly rocked the bolt back and forth with great patience. We also kept soaking it with PB Blaster.<br /><br />Worse case if you have to drill her out and you ruin the threads is to install a HELICOIL. These require you to drill out the area slighly larger than what you have now, and insert the Helicoil with gives you threads again.<br /><br />Good Luck and email me if I can help in any other way. (Email : jmetaxas@aol.com)<br /><br />John from Madison, CT
turtle1173
I went this evening and found some PB Blaster. I sprayed down the broken bolt as well as the bottom one that is stuck. I'll see if she'll budge any tomorrow.<br /><br /> I also bought a center hold punch and an EZ out. I'm going to take it slow and easy. I tried to find a left handed drill bit but the place I was told that had one was closed. I may try to get one tomorrow.<br /><br />Thank you all for your help. I will keep you updated on what happens.<br /><br />Shane
dkondelik
Good Morning & Good Luck Turtle,<br /><br />As has already been posted, BE CAREFUL WITH THE EZ-Out. They are VERY hard and VERY brittle. Also, they are tapered. As you apply torque, they have a tendency to want to expand the diameter of the captioned bolt shaft thus adding to the siezing problem.<br />I have had frequent problems with them BREAKing off in the the bolt shaft. This is a BIG problem. The last time this happened, I ruined 7 end mills and same number of hardened drill bits to auger out the broken EZ-out. The only good news was that in the process of drilling out the broken EZ-out, I also got the broken bolt.<br /><br />I would listen to 12Footer. Earlier in this thread, he suggested taking the entire rig to a machine shop. This might be a tad of an expence up front but, in my never-to-be-humble opinion, will be well worth the savings in aggravation should your EZ-out break.<br /><br />Good Luck!
brent suzkui wyble j16
take your time.if you mess it up Johns idea of using a Helicoil is great. i've use them working on helicopters in the pass, they are strong and bring the bolt size back to orignal.
If you are going to do this yourself, I have to again reiterate how important the application of heat was.<br /><br />You will NOT melt the aluminum, but it will expand faster than the steel bolt. The slight difference in the expansion rate might give you enough to turn the bolt out.<br /><br />I am assuming by the way that you are taking the exhaust plate off to get to the bolts. If it's still on, the heat will be fruitless.<br /><br />John from Madison, CT
Hooty
If you're sure you're gonna use the easyout, before you certerpunch it, use a blunt punch and flatten the broke end of the bolt so the centerpunch won't walk around and you can hit the center of it. Start drilling with a small drill bit and work up to a 1/4" bit. Do this in three or four steps. Use plenty of coolant (oil) on the bit when drilling. Also hammering the bolt with the blunt punch may help loosen it.<br /><br />g'luck & c/6<br /><br />Hooty
lpkirby
My experience with the easyouts are not good, I almost always came out in a worse situation. Good luck and take it slow..
ob
Turtle,if the broken bolt is slightly below flush and you haven't removed the cover yet , I'm wondering if it is slightly below flush with cover or engine block.Cover is not threaded.Before attempting any drilling after soaking bottom bolt and removing, if all goes well,remove cover and see if you are able to get vise grips or stud removal tool on broken bolt shank.<br /> When removing bottom bolt , if it seems to start binding as was case with top one, instead of continuing backing out ,when it starts binding screw it back in and out in an alternating direction so as not to gall the threads and cause breakage.
cpasseno03
Im not exactly sure what bolt your after, but if you ever get to the back side of it, you can drill into it and after a nice hole is made, **** the drill and sometimes the bit will catch and send the bolt out real nice....sometimes. Probably wont work in your case because it doesnt sound like you can see the back of it. I concur with the people that reccomend PB blaster and a torch, and tapping it. Then drilling and EZ outting. It takes some patience...<br />Good Luck<br />Craig
gotta say that I think that a bit of heat is the way to got if you can get it to where you what it with out damaging any other parts (eg seals gaskets wires etc.)Liked the Idear or welding something to it as this would give some thing to get a hold of and maybe heat it up enought to do the job and go slow real slow<br />cheers daryl
