The tilt and trim on my 1994 Force 40hp motor (serial number 0E067660) is leaking down. If I bleed out the system, then I don't have any issue (motor will hold position and will not fall down). However, after a day on the lake, leak down will reappear. I think there's a leak in the seal of the cylinder because the pump works great and no fluid is leaking there. Is there a rebuild kit for the cylinder or do I have to replace it at the cost of $500 just for the part? Thanks for your input.
