I have a 1989 Force 125 hp dual exhaust and at idle and low speeds there is A lot of water coming out of the two pee holes
on the back of the motor. At higher speeds it stops. The impeller has been replaced. The gear case is not original , the original was a single exhaust. I believe the shop used the impeller pump set up off the original single exhaust gear case for the replacement dual exhaust gear case but put a new impeller when installed on the dual exhaust gear case. Is it normal for the water to stop at higher speeds on this model gear case?
