Push in seat o-rings - cheaper alternative
a_scales
I ordered the Fk10120-1 kit just for the o-rings on my Force 125’s carburetors, but I also took a chance and ordered what I believed were the same rings from amazon, and I was right. They are exactly the same dimensions as the ones in the kit, and are cheaper and easier to get. if anyone is looking for the carb seat o-rings for a Force with push in seats, these might be worth a try.
Harbot 20pcs Carburetor Float Valve Needle Seat for 398188 281144 299096 394681 83400 5HP 6HP Vertical 3.5HP 5HP Industrial Plus Engines https://www.amazon.com/dp/B0761T839J/ref=cm_sw_r_cp_api_i_CCxjFb2RKS0DD
